Re: Gas tank uptake question
You seem to have narrowed down the restriction to the area upstream of the fuel bulb. Common causes for upstream restrictions include:
1) anti-siphon valve. This is located on the tank where the fuel hose connects to the fittings on the tank. Search for the term "anti-siphon" and you will find more information on troubleshooting and fixing this potential cause.
2) siphon tube. This tube can be plugged up at the tip. There may be a small screen thingy at the tip that is dirty or there may be an obstruction at the tip if there is no screen. I have also heard where tubes happened to be just the right length that the tip is pressed against the tank wall and restricting flow through the tip's opening.
3) Collapsed fuel line.
You might also consider blowing some air backwards through the fuel line to see how freely it passes through. You can also hook up a vacuum gauge to the fuel line to help narrow down the problem. See below thumbnails for more guidance.
