gas tank size, any one know?
crzy4wlvs
Im stumped as to how much my gas tank holds. I have an 1979 out board Gypsy star....any know or need more info? :confused:
crzy4wlvs
Re: gas tank size, any one know?
I just wondering cause Im adding some fuel stabilizer to it, and it is half full
LarryMP
The size of your motor has no relation to how many gallons of gas your tank holds. Find your gas tank and measure it [length, width, and height]. Measure it in inches and multiply the LxWxH this will give you how many cubic inches your tank has in volume, divide that by [144] that is how many cubic inches there are in one cubic foot. now you know how many cubic feet of volume your gas tank has. One cubic foot of volume equals 7.5 gallons of gas, so multiply the volume of your gas tank in cubic feet times 7.5 and that will tell you how many gallons of gas your tank holds. Good luck.
Solittle
I don't know your boat but many tanks have a data plate that gives the inf. Look under any inspection plates. Mine is on the tank near the filler neck.
JB
Moving to Boat Questions
sloopy
Fill your tank up all the way. Multiply the amount of gas you put in by two, then times that number by 1.3 and add the appropriate amount of fuel stabilizer to it. TOO MUCH DOES NOT HURT. the 1.3 is a safety. The best thing to do though is empty the tank.
