Re: Gas tank question
Its a single line. They didn't have pressure tanks on those motors. You are probly looking at the gas prong, and the clip prong. Plus another thats a guide. I have the same motor, only a 63 40HP Evinrude Selectric in my stash out back. Just went out and checked. Standard Johnson fittings, so any boat store, even Walmart has the hose. You will need a tank, and any plastic tank will work. but Metal might be a Ebay iten. Theres some clean ones out there. You will just need the Johnson fitting for the tank if you do plastic. Then your set! Good Luck!
