I've posted several discussions regrding my 140 VRO bogging down at WOT<br />Found a loose connection of tubing running from <br />gas intake nipple to inline fuel filter. <br />Now engine runs more cosistantly correct at WOT-<br />and when it does bog down (still does but not as much) it runs at 5000 rpm instead of 3500-4000.<br />(when running correct-6000-6200 rpms)<br />Still sounds like its trying to kick in all the way<br />New sympton developed- One time it went from lower<br />speed to high speed at MUCH! slower delayed rate.<br />When it got there (WOT) it ran smooth<br />So there is an improvement. I was advised to cleanout the filter on the pickup tube inside the gas tank.Since this boat is a 1977 Formula- the tank is 25+ years old. Saw the line leading from the tank to the fuel separator but I'm scared <br />to fool around with possible spark/gas.<br />One thing to mention- 3 wees ago I emptied about 3 <br />gallons of gas from the tank by pumping the primer bulb to correct gas/water problem. Wouldn't I have noticed a diminished gas flow if the filter was clogged? Thanks for your advice
