Gas pumping out of the top of carb
nascarschool
the gas is just pumpingb out of the top of the carb, it ran great the other day and when I was WOT on the lake it bogged down and chugged along until it stalled I looked at the engine and could see gas dripping out of the top of the carb.....any help would be great!!!!!!!!!!!!!!!!!!!!!:confused:
Don S
Re: Gas pumping out of the top of carb
What are we working on here? See sticky at top of this forum
Basically, sounds like it's time to open up the carb and rebuild it and find out what's in there causing the needle valve to stick open............. if that is where the fuel is coming from.
nascarschool
Sorry it is a 1977 120hp OMC 2 barrell Rochester...the gas is coming out of the chute in the top of the carb...the slanted chute is that the needle?
Don S
Not trying to be mean, but you need to find a mechanic.
nascarschool
is it something that can be fixed or should I get a new carb or what do ya think
Ayuh,......
It's probably Easily Fix,....
Get a Carb Kit,+ Rebuild it.....
