Gas pouring from carb
albaris
I have a 1975 Johnson 135HP. I notice that when I shut the engine off I get fuel pouring out of the carburator(sp). Not just a drop or two, but quite a bit. Anyone have any idea why this is happening??<br />Also, I need to know what charges the battery on this engine. I am new to outboards, and I don't see anything that resembles an alternator or generator. Please help<br /><br />Thanks<br /><br />------------------<br />Al Baris<br />Clyde, NY
Backlash
Re: Gas pouring from carb
Is the gas pouring out of just one of the carbs? If so, probably a float problem, sticking or maladjusted. The alternator is under the flywheel.
chasec
the alternator in an outboard is under the fly wheel . this alternator is made up of two parts the flywheel with cast in magnets <br />, and the stator assembly which is bolted to the crankcase. the stator is made up of coils <br />wound over a laminated iron core. The flywheel turns around this assembly inducing alternating current. Then the rectifier assembly converts the alternating current into direct current.<br /><br /> hope this answers your questions about the outboard alternator
Has the motor been sitting up for a while? It is most likely a float sticking open.<br /><br />Good luck!<br />Brett
