Re: Gas Over Flow
Generaly if the vent is installed correctly (many are NOT mine had a 360 loop in the vent line
from the factory) it will come out of the vent first
When i changed it to the route in CG guide it worked much better
A big issue is that many tanks will only fill correctly when there dead level as the vent and fill inlet are at the rear of the tank and most times on the trailer the bow will be a bit high
Many times the sharp 90 DEG fill inlet will only allow a low fill rate as it catchs air farts
and backs up
You have 1-1/2 line going in and only 5/8 line to vent the air flow which is also restricted by the spark screen in the vent
Tommays
