gas,oil and water mixture
hayesd18
I recently went to change my oil and the oil was very milkshakey. I know there are numerous posts on this butto me it seemed to have gas mixed in as well because the mixture was very consistent and obviously smelled like gas. but the water and oil weren't seperated like I thought if it were just water and oil. I recently replaced the riser and am in the process of replacing the manifold. To me the manifold didn't show any obvious answers nor did I see any cracks on the engine block. I don't think freeze damage is a suspect just because it has always been stored in a garage. stumped
Don S
Re: gas,oil and water mixture
Go up to the Adults Only sticky at the top of this forum. Lots of information in that section, especailly read the FIRST topic.
I recently went to change my oil and the oil was very milkshakey. it seemed to have gas mixed in as well because the mixture was very consistent and obviously smelled like gas.
Ayuh,...
You've got Problems,... Multipule Problems...
Gas in the oil makes it runny,+ stink like Gas... Probably a Bad carb or fuelpump...
Water causes the Milkshake.... Probably a cracked block..
And,....
It would be nice if you told Us just What the 'ell you're working on.....
