gas lines to fuel pumps
Ian
I removed the fuel pumps on a 1998 35 HP Johnson and now I have forgotten which of the two connectors on the bottom is the correct one to attach the fuel line to and which is to share between the two pumps. It would be great if I could find a manual but this long weekend the shops are closed.
Yepblaze
Re: gas lines to fuel pumps
Hook up a long hose to one or the other and blow. You should see that one way allows you to blow and the other way won't. Thats the way the fuel goes, as there are probably two one way check valves in the pump.
