I have a 1986 115 hp. merc and it runs great at WOT. I rebuilt the carbs, new gaskets, needle and seats, new jets, adjusted floats, I even put new throttle shafts in the carbs. They did appear to have very little play, but the housings are worn somewhat. The trouble is during idling, gas seems to build up from the top carb and the middle carb, and drips down the throttle shafts and runs down and eventually drips down the bottom carb's throttle shaft also. The gas leak is worse when I shut the engine off and let it set for a while. It is a steady drip about every 10 seconds or so, for about 30 mins. to an hour. and then quits. It's driving me crazy! Also the motor seems to load up on gas when at low speeds just above. idle. When it's cold, starts right up will idle great about 800-1000 rpm when trying to motor around up to the dock slowly it wants to die. Sorry to be so long, but wanted to try and explain everything I've done.Can gas leak down these shafts because they're worn? Or due I have other problems like incorrect float levels. I've even taken the top off to inspect the float level and it's about 1 and 1/4 inch from the top of the bowel, not overflowing. I just don't know where the gas is coming from to drip down the throttle shafts like it does. If I could fix the leak maybe the loading up issue at low speeds would stop, or at least I could deal with it, I hate gas leaks. Please someone help, with any ideas. Thanks! I have only had this boat a month and a half and I have an online manual, but am ordering a book.
