Gas leak from lower unit
Mikeiv
I have a Yamaha f115bet 2018 model, which recently developed a gas leak from the lower unit. I changed the low pressure pump the leaks stopped for about a month and began once more . Any suggestions to this issue
99yam40
there should be no fuel in the lower unit, so why should it be leaking from it
robert graham
Maybe it’s leaking from up around the power head and drumming down inside the leg and dripping out the lower unit?
Mikeiv
So after viewing today I notice that the gas is coming from the carbon canister and down its drain line
