gas in oil
blackz3
1987 omc 350 has gas smell in oil... everything seems to operating fine just has the smell of gas in the oil even after 2 oil changes.. what could be the cause??
Limited-Time
Re: gas in oil
First stop the mechanical fuel pump. If the diaphragm goes bad you can get gas in to the oil.
Haut Medoc
Re: gas in oil
How's the compression? Blow by could cause this. Not an omc guy though. Ruptured diaphram in the fuel pump?....JK
KaGee
Re: gas in oil
Originally posted by J.kopec:<br /> ...Not an omc guy though. Ruptured diaphram in the fuel pump?....JK
SBC is an SBC, no matter Merc or OMC. Check the vent line going from the fuel pump to the carburator for signs of fuel. Fuel in that line confirms a bladder rupture and replacement of the fuel pump.
Re: gas in oil
I've seen Worse........<br /><br />I think the Fuel Pump just might be your Issue,.......<br /><br />If Not,.... The Carb. has got to be the Problem........
blackz3
Re: gas in oil
could ya tell me how to find out...what test to do to the carb and the pump
man-of-war
Re: gas in oil
THE PUMP, KaGee told u how. THE CARB, rebuild it.if that does not work and u still have the gas smell.see your michanic ASAP .Ive walked that way ,now im rebuilding the engine and a new engine block.look for MAN-OF-WAR on this site and enjoy.......
blackz3
Re: gas in oil
thanx M O W that helped alot...hope you got your problem solved
rbezdon
Re: gas in oil
Heed Man of Wars warnings. He is living the nighmare of running the engine with gas in the oil, one of the worst things that can happen to an engine as well as one of the most dangerous. Find the source and fix it as quick as possible and dont run it.
blackz3
Re: gas in oil
pulling it out of the water as we speek <br />thanx again guys
