buddhamouse
- Apr 7, 2004
- 2
I have a 2000 40HP Honda with a lot of gas in the oil. When I pulled the dipstick it poured out. The engine starts, runs and idles great. Other posts have said to check the fuel pump, thermostat, or carbs. Since it's running so good, I doubt that it's the carbs. How do I test or check the thermostat or fuel pump? Would this type of pump be able to inject gas right into the oil sump through a faulty diaphram? And I noticed that when it's running, saltwater leaks out the rubber gasket surrounding the oil pan drain plug??
