Installed a rebuilt 350 GM engine with a 4bbl carb. Ran the recommended 10 hours break-in period. Changed the oil, and got out 6Qt of thin, black oil when I only put in 5Qts.<br />Assumed a fuel pump(external, electric) and/or carb problem so installed a rebuilt carb and put an adjustable pressure regulator on the gas line set at the recommended 4psi. Ran the boat another 10 hrs, changed the oil with similar results!<br />I need to resolve this before the boat blows up!!!! <br />BTW, the boat & motor runs fine.<br />Any ideas on possible causes???
