Re: gas gage problem
If I remember correctly the sender should read about 200 ohms when the float is in the full tank position. Sometimes the senders will stick and not move when they get old. If forget how many ohms it sends when empty, some low number. Then also check the fuel gauge at the dashboard. Most likely the sender is bad or the ground is bad.
If you decide to replace the sender, beware of the instructions on how to cut and install the new one. Make sure you remember, memorize, take pictures, whatever you need to do, how the old one comes out. The new one needs to go back in that very same way. Also when you take the final measurement of the float height, use a piece of wood or a table, rest the float of the sender in the down position (empty) so it barely touches the table and measure up to the bottom of the plate that sits on the tank. That is the proper measurement of the final height. When we learned in my tech class how to install a fuel sender, the instructions read like a Greek script from 300 B.C. There were all sorts of math equations and other types of blabber on how to measure and cut etc. Bottom line the teacher held the sender over a table like I described and measured the length and we all did it wrong. Easy fix though since the sender gets screwed into a metal type of bracket that hangs it into the tank. You'll see what I mean when/if you replace the old one.
