gas and oil line difference?2000 150 h.p. johnson
oddysea1
I am looking to change out my gas line from the bulb to the fuel pump{sun damage} same issue with the oil line-it is attached to a long oil line from the oil tank.From that connection to power head it is about the same length as fuel line.My question is-is that the same kind of line- size and material. If so I am assuming just to bring in both and have them cut it to length.I just want to make sure the oil line is not special or different and needs to be ordered if not in stock.Thank you for continued help.Regards Andy
jakedaawg
Different I.D. I believe. Fuel will be 3/8". Oil is either 1/4" or 5/16". Cant remember for sure on the 150's...
oddysea1
Thank you I will bring them both in for eye comparison-Regards Andy
