Garmin GFS10 Fuel Sensor - no reading tank
winbasic
Hi,
Has anyone had any experience with the relatively new GFS10 fuel sensor from Garmin? I've had it installed and on the 2nd attempt, the marine electrician found out that there is an accessory cable required of some description to make it read the flow correctly. So now I have the flow rate being displayed on the GPSMap 525s unit but even after calibrating it, I can't get any tank level reading. It is an anlogue sensor on the tank and I believe the GFS10 has been hooked up to it but I'm wondering if there is something else missing. It is connected using the CANNET cable.
Kind Regards,
David.
