Gamefisher 9.9?
armyhooah
I just had this motor given to me.
Have no clue as to where to start?
Lion hunter
Re: Gamefisher 9.9?
Dang, how many motors do you have given to you? LOL. That one looks like it's had a rough life. Check for spark first, not much use going any further if it doesn't have that. Got spark? Then it needs a good cleaning, carbs cleaned, (looks like it's got new fuel lines), change lower unit oil, new plugs. Then put in a barrel and see if it will run.
steelespike
Re: Gamefisher 9.9?
Look for a model number probably on the mounting bracket.
If it begins with 217 it is an Eska built motor.typical history is weak ignition.
As I understand it some ignition parts are now available through one of the ignition specialty houses.Someone should be along with that info.
If it begins with 225 it will be a Force. Somewhat better parts support though both companies a long since out of business.
Look for waking a sleeping outboard at the FAQs section.
CATransplant
Re: Gamefisher 9.9?
An aftermarket unit is now available for those ignition systems. CDI Electronics makes it.
It's over $200, though. You have to really think about whether you want to put that much into that outboard.
You'd be hard-pressed to get over $200 for a running one of those Eska-based 9.9s, so unless you're in love with it, part it out if it doesn't have spark on both cylinders.
Those things will break your heart.
armyhooah
Re: Gamefisher 9.9?
Yea...we have spark.
Next the lower unit. Then the carb. Hope this old thing works!
Carb question?
Is there suppose to be a gasket around the float bowl lid?
