Please delete this posting. Sorry, was thinking this motor was made by Tohatsu, but now realize it''s Tanaka. Reposting this in the "other outboard" forum. I bought a used Sears Gamefisher 1.75hp awhile back. Never ran it till today. I put fresh fuel in with a 50:1 oil mix, using oil for air cooled engines.
Started on the second pull, runs well except I cannot get it to slow down to an idle where the centrifugal clutch for the prop drive disengages, running probably at half throttle. I only see one adjustment screw on the carb. Tried it but seems more of a fuel needle valve. Cable from the handle goes into a plastic cap on top of the carb, don't see any real adjustment here. Cable does seem to move well within its' cover.
Any suggestions?
Thank you, Bill
Any suggestions?
Thank you, Bill
