Galley Removal!
HornSpacer
Hi
I have 87 Wellcraft Antigua 265 and the galley was removed and replaced with a bench and storage out of a couple sheets of plywood. Ive seen pictures of the galley looks like it would have weighed more than what was built. I was wondering should I add some weight as the original design was changed and how much the galley would have weighed the sink and stove cabinet and counter top. I was thinking around 80 to 100 lbs.
Thanks
[size=8pt]ดูบอลสด[/size]
tpenfield
:welcome: to iBoats . . .
Don't worry about it. If the boat seems unbalanced in the water then you could consider adding some weight, or moving some of your gear to that side.
a case of beer is 36#, so bring along 2 cases of beer.....
