TexasMark and Mike, Thank you. Great suggestions. With my 81 yr old shaky hands, I fear grinding could make thing worse. If I gently drill small holes, and gently push G-Flex 650 Toughened Epoxy into the crack and newly drilled small holes, then smooth the surface and lightly sand with 400 grit, then find a touchup paint that is close to the dash color to cover the crack. STEERING is dual cable, so TexasMark's suggestion to adjust the wheel by adjusting the motor-end cables (lots of thread left), may be the only solution. I think I'll try just gettin used to an upside down wheel. BILGE: It worked last year. I'll clean and test the auto bilge pump. Maybe I've forgotten something to make it work again this year. LIVE WELLS: The only problem child is the middle well, port side. Bow live well doesn't fill, and stern well is manageable. I'll try all your recommendations for port side middle well. I've already put compressed air and "snake" though, but there seems to be a check valve, and maybe that is stuck. Somehow, I need to find the input, and close that off since I never use that well, just the stern well for Lake Michigan salmon, steelhead, and lake trout (more fun that a barrel of monkeys!!). Currently, Lake Michigan is low 40's, and weather outside is about the same. Needs to warm up before this old man will venture out. Grandson and me on Beckoning IV.
