mshiff62
Thread starter- Joined
- Jul 5, 2013
- 36
I have a 1987 Force 15hp and I took the lower unit off and I think that I may have adjusted the shift linkage wrong. Anyway, spent about an hour adjusting it all different ways, I finally have it where it seems right, it will go into FWD and lock in and it will turn the prop clockwise with pressure against it, neutral is good, but then when I put it in reverse and spin the flywheel theres no pressure against the prop. Anyone have any experience with this or know if it will only go into reverse if it is running? I have tirelessly researched and came up empty handed. Anyone with any experience or input will be greatly appreciated! I have put a lot of time, money, and work into getting this motor going again and this is the last straw to complete it so I can see if it will run.
Thanks!
Thanks!
