FWC for Mercruiser 260
mjdown
Thinking of installing a Full Fresh water cooling system for block and manifolds on a merc 260, GM 5.7L engine.<br /><br />- Q1 Is this a relatively easy install and is there any recommended brands? Do these kits have evrything I need?<br /><br />- Q2 Will my impeller provide enough PSI input for the Heat Exchanger to work effectively or would I have to move to another type of intake.<br /><br />Any feedback would be appreciated.
Trent
Re: FWC for Mercruiser 260
The installation is really not to bad. It really depends on how much room you have to work with. Alot of the time you will have to remove the impeller from the outdrive and install a belt drivin waterpump to provide enough for the new cooling system.
