I originally had two circuits hooked up to the single battery on my 15 ft boat. One was the OB motor and the other accessories such as lights etc. I added a few more things and ran the wires (14g) right from the accessory to the battery (cig lighter, compass, fish finder). These are all on separate circuits running to the + and - of the battery, I didnt want to combine anything on one wire before it reached the batt. They are all fused as recommended. When everything was hooked up (motor, original circuit, and the 4 or so new ones) to the batt first the cig lighter fuse 15A blew so I put in 25A thats fine now. Then I tried and everything worked including the OB for a while so Im sure the wires arent reversed anywhere. But right now neither the motor nor the original accessories circuit will work, I suspect its a fuse in the latter which I think also controls the OB through the ignition. Can anyone make some sense of this and tell me what steps to follow to figure out whats wrong? (I guess the first one would be to disconnect all the new circuits change the fuses and see what happens but then what?)<br /><br />Thanks<br />J
