On the lake today, at one point turned key to start and nothing. Also trim/tilt was dead. Looked and found a 20 amp fuse on a red wire had blown. To get back home, used a bent fishhook to replace fuse, it more or less worked but the volts gauge was going crazy, showing 3 volts charging at low rpm's then jumping up to normal at higher speed, also rpms was showing wrong, 2 or 3 times too high, then coming back down. Fishhook fuse blew again when adjusting trim, made another one and got boat back to trailer.
Looked at motor, grounds and connections look fine but I don't really know. Is there such a thing as a voltage regulator on the charging circuit, and is this what went bad? Or is it more than likely a bad ground, or could it even be a battery problem? I think I know where the voltage regulator is, if that is it.
Thanks for any help
Thanks for any help
