I have an 08 Tahoe with a 4.3L mercruiser engine. Boat started on its own last year in my driveway but didn't run long. my neighbor saw it and turned key on and off, it still ran. Disconnected negative battery lead and it still ran. Disconnected positive terminal and it finally died. Very strange. We decided to mess with it next year. So 2 weeks ago we dove into it. Had dreaded starter click. Pulled starter and had it rebuilt. With starter back in, I went to start it and after 2 tries it kicked over and died. At this point I lost all power to ignition switch. Still had power and good fuses at panel under the dash. traced main ingnition wire back behind carburetor and found 15amp mini fuse (also discussed in this thread) https://forums.iboats.com/forum/eng...hidden-fuse-on-4-3-tahoe-q4-please-help/page5
I replaced the fuse and the boat again would go to start but the minute the engine catches and is kicking over, fuse blows and it dies. I even replaced the ignition switch for grins. Im guessing I have a short somewhere but I don't know where. Ive checked all the wires against the motor and none are melted. Ive checked and cleaned battery leads and terminals. just hoping someone has had this issue before and can help out. Ive got a 5yr little girl who tells me every time she see's me, daddy I want boat!
