FORUM RULES UPDATED - The forum rules have been updated to continue to provide a friendly and safe environment for our member community. Please take a moment to review the updated rules and our terms of use and privacy policy. Click here for Forum Rules which has links to the 'terms of use' and 'privacy policy'.
In Other News . . .
You will notice a few enchancements to the forums to make your experience better. These include: Email Notifications, Thread Previews, Thread Starter Notation, and Emoji Options on the 'Like' icon. . .
Additionally, the merchant portions of the website have been updated and are now operational. . . . Check out iBoats for all your boating gear.
No meaningful advantage blades have less surface area to corrode, but you shouldnt have corrosion in there. Have you thought about upgrading to a circuit breaker panel?
Thanks for the reply 18rabbit. Corrosion is the reason Im replacing the old one, I guess after 20 some years theres no stopping it. Any way I found an auxiliary fuse block (blade style) for a Crown Vic on Ebay that looks like it will more than do the job. The current bid is $18.50. As far as upgrading to circuit barkers the boats not worth all that.
Don't you think it might be worth the couple of extra bucks to head to your local marine place and buy a fuse block that has tinned connectors?<br /><br />Thom
i post this all-the-time.. o'well whats another..<br /><br />i lite coat everythin' that's not soldered.. bulbs, contacts, fuses, trailer plugs ,ect with aluminium wire oxidation compound,, i.e. NO-LUX,PENETROX, bear grease.. buy a small tube at any hardware store 2 bucs.. good stuff .. keeps away the 'greenies'.. little-dab-will-do-ya..
Hay crab bait you and I are on the same page. As I posted earlier this is a small fishing boat over 20 years old. In fact if it were not a Boston Whaler it might not have lasted this long given the treatment by previous owners. Im not running an inverter or even a fresh water system so fuses should be fine. ThomWV, thanks for the advise about tinning the connectors I was planning to do that and use heat shrink on any butt splices. The other idea Im knocking around is to incase this fuse block in some kind of watertight container and seal what ever holes Ill have to make with silicone, maybe Tupperware. Any thoughts on that?
Hi Outrage,<br /><br />Just to throw in my thought on sealing the fuse block. I would be afraid that might promote corrosion from condensation. I think I would do as crab bait suggested and let it go from there. Plus, access might be a problem if you seal it up tight. Just a thought...
If you look at all the electronics around your house, anything that plugs into the wall or takes a battery, how may items do you see in sealed containers?<br /><br />Ditto Crab Bait and RB.
Not many 18rabbit but the bare wire connections are always in a junction box. I know this is not to stop corrosion its to limit the amount of oxygen available in case of a fault.
