i have a 1990 javelin w/johnson 120 hp o/b. i recently replaced the ignition switch and may have blown a fuse(s). i found a fuse block under the dash and all 8 fuses were ok. does anyone know if there is another fuse block or something else i can check. i found 1 inline fuse and it was ok also. before replacing ignition, i had lights, horn, gauges, etc. now i have none. anything else i can check?
