Re: Furuno LS 6100 Beeping all the time
Presuming that what you're hearing is an alarm, you should see an alarm icon on the screen. The icon will tell you which alarm is activated. (Did you recently do something to set an alarm on so that it would activate when the preset is sensed?) The LS6100 has 6 alarms: (1) bottom, (2) normal fish, (3) bottom lock fish, (4) water temp, (5) arrival, and (6) speed. Dunno if you have (4), (5), and (6) which require special sensors, but either way, all alarms can be turned off, but must be done so individually. Follow your operator's manual directions to get to the menu that allows that. Good luck.
