Hi all!<br /><br />I posted a message not long ago that i had problems when my engine wouldn't start anymore - no spark. It's a 3.0 Volvo with a brand new DELCO HEI distributor. The coil was also new. Now, the problem is, when i stop the motor, it won't start - the spark is gone. I tryed to change the electronic module and the thing worked so i thought i solved the puzzle. Now the problems came back - same symptoms. So i thought: either the coil or the distributor itself. As a last resort, i tried to change the wire going from the distributor to the coil (2 pins) - i had a brand new one from the new distributor, but i used the old one in the wire harness. The thing started right away! Hmmm... was this causing the trouble? What do you think? The number on the cable is 7982 - and i noticed that something is integrated into that cable (a fuse perhaps)? Any ideas? What else should i check?<br /><br />Thanx for all the great ideas in advance,<br /><br />Alex
