sms986
- Sep 18, 2017
- 334
So long story short I got roped into repairing two jet skis for a family member. One is up and running, the other, a sea doo, is doomed. I have enough know how about engines to do the repair, but I've never done anything with jet skis so I'm limited on the specifics. The engine mn is 5836. My uncle said the engine was replaced by previous owner and smoked very bad. Doesn't look like the engine was replaced. If so, it was an eBay used engine. I found tons of oil in it so I figured I'd better pull it apart. Both cylinders' crankcases were full of oil and the magneto housing was too. I'm thinking a) "new" engine had bad bearings that ate up all of the seals, b) the seals were just worn out, or c) the engine wasn't aligned and it tore up the seals. Either way, thanks to this fancy rotary valve engine, the whole crank will be replaced (it actually looks pretty good). So I'm left with a complete rebuild and I'm in the process of gathering new parts. My only question at this point is regarding the stator and stuff. It took a HEAVY bath in oil. I don't know if these are wet or dry systems, but it looks like it's supposed to be dry to me. Will any of these electricals be any good? I doubt I'll ever be able to dry them off.
