I just purchase a 98 RENKEN 1880 with a 115 Johnson. First boat I have done some work on it before putting it on the water, no gage was working and steering cable was bad, plugs and gas filter was changed and I added 10 gallons of mix 50:1 to an existing 10 gallons.
it started fine with a minor fault. With out the gears it rev perfect up to 5,000. On the first outing after going 30MPH on about 3,000 RPM it was perfect until I slow down on a no wake zone.
Know on full throttle and 2,500 RPM it will not go higher than that. it will only go about 4 MPH you do feel like the engine is like in need of air or gas, I don?t have a water temp gauge, but I can see the water coming out with pressure and not hot. The volt 13-15, nb It rev up to 5200 rpm without load (gear not engaged) and it is fine. I don?t know if this is normal when i changed the gas filter the old filter was full, when I installed the new filter it was empty do I need to fill up with gas the new filter before installing it.
Thank you in advance.
