Is there anyone out there with a 1988 Starcraft Islander with the Merc 4.3? I just got the boat and was reading throught the generic MerCruiser Operation and Maintenance manual and it says the fuel-water seperator should be changed annually. As far as I can see in this boat, a rubber line comes from the fuel tank and runs straight to the fuel pump, and then a hard line comes out of the pump directly to the carb. I found the little filter in the fitting at the carb and cleaned that screen. Also, is there a screen on the pickup inside the fuel tank that should be cleaned/replaced?
Thanks
Thanks
