fuel/water separator
MiamiU
Is it common to have a separator on an outboard. I have been told that they do not work on outboards.
I have had water get in my fuel twice now, causing major headaches. I was hoping this might help with this problem.
Is it done?
How is it done?
Does anyone recommend a brand?
thanks
Chris1956
Re: fuel/water separator
You may use a water seperator on an outboard, but you need to use one that is rated for the gal/hour that your motor uses. Typical water seperators will state they either are or are not suitable for outboard use.
I installed one on my 150HP Ocean Runner. It works just fine.
rickdb1boat
I've always used the canister type on my boats with outboards and never had a problem...
WaterWitch2
Which side of the primer bulb should a separator be installed?
burroak
What is the effect of a fuel/water separator when ethanol added fuel is used? If the water is bound to the ethanol will that get trapped or passed through?
iwombat
Tank->separator->primer bulb->fuel pump.
Ethanol will bond to some of the water, but if you've got open vents in a marine environment you'll quickly saturate any ethanol holding capacity.
