Hello all,
I'm hoping I'm putting this post under the right topic, if not just let me know and I'll move it.
I have a 1999 Lowe GLS 190 fish and ski boat with a 2003 Johnson 150hp outboard.
I bought the boat back in 11/16 and from auction and it sat for several years. (This was actually a PA Fish and Boat commission boat)
Without removing the gas tank since the deck is a solid piece of aluminum, I drained the poly fuel tank through the fuel sender opening to where it looked clean and there was no visible liquid in tank. Since I wanted to put a Moeller Fuel/Water separator on it and had to wait for it to come in, I ran the boat using a 6 gallon marine tank and the boat ran like a champ!
My problem began when I put the fuel/water separator on the boat. I mix the oil (50:1) directly in the fuel tank and it seems like the separator is filtering out the oil.
I've attached (hopefully) two pictures. The first one is fuel directly from the tank (on left in pic) and through the filter (on right in pic 1) Picture 2 is a close up of the liquid filtered from separator. After a day or so, there was a very slight amount of water in the container directly from the tank, but it wasn't even enough to cover the bottom of the bottle. (Had to tilt on site to even see it)
I'm at a loss on this. Could the filter be filtering the oil out?
Any help for this newbie to boating would be appreciated!
![fuel pic 2.jpg fuel pic 2.jpg](https://forums.iboats.com/data/attachments/262/262729-73111766472ae3729eae2cf2ec52d881.jpg)
Dave
![fuel pic 1.jpg fuel pic 1.jpg](https://forums.iboats.com/data/attachments/262/262727-2ca038a96b0793e459b3f0801e680662.jpg)
Dave
