Fuel/Water Separator and VST filter....
smann
Was fishing out of Cocodrie, La Sunday and my 2001 F115 was running like a champ and then all of a sudden it started spitting and sputtering. I eased back to an idle for a minute and then when I accelerated again I got to 6.2 mph at full throttle. Luckily I was able to call the guys at Ship's Chandler in Destin and their mechanic, Mac, walked me through a couple of things to check with no success. I was unable to remove the fuel/water separator filter and he said it sounded like a clogged VST filter. So not to be undone and so we fished all day and idled 13 miles back to Coco Marina drink cold beer and listening to Skynyrd.
Got the intake manifold off and got to the VST today and it was clean. I put it all back together and replaced the fuel/water filter. i fired the engine and she ran perfectly. i was able to get good rpms multiple times. I am going to the lake Saturday to really test it out. Fingers crossed.
The moral of the story is, before you strip off the intake manifold and VST, replace the fuel/water filter and see if that solves it. I think would have in my case. Oh well, at least I know how to take the manifold apart if I need to.
99yam40
Re: Fuel/Water Separator and VST filter....
best to take what is needed to monitor fuel pressures in case it is not better.
Running with out load does not mean much
smann
You are right. It ran no better. I have ordered a ne fuel pump and sent the injectors to be cleaned. Fingers crossed.
99yam40
testing is the best way to troubleshoot problems.
Replacing parts and hoping can get expensive, not to mention frustrating.
Ldavidgrover
You should start with doing a compression test first before ordering
smann
The only part I have purchased is the pump. My thinking is that whether it is the problem or not, the old pump is 11 years old and a new new is not a bad thing. I also am not sure if the injectors have ever been cleaned, so that's not a bad thing either. If this does not solve the problem, I'll take it to a real mechanic.
