Hi Folks.<br /><br />Yearly inspection time before May 1 drop-in..<br /><br />Because I am a paranoid, I inspect the fuel tank and replace the hose clamps to the tank. I re-crimp terminations to grounding rings and to the gas level sending unit.<br /><br />Maybe I'm too far over the edge.<br /><br />But a question:<br /><br />The fuel tank is a 88 gallon 2021 grade aluminum tank.<br /><br />It stays dry, mostly, but I do see "chalk" oxidation on the exterior surface.<br /><br />Is there a replacement interval required for a 2021 grade aluminum tank? If so, what is the interval?<br /><br />Any other maintenance required, aside from inspections?<br /><br />Any suggestions are appreciated!<br /><br />Thank you.<br />Ken<br />Red Bank, NJ
