I have a '94 trophy, center console, with a 30 gallon fuel tank. Prior to my last fill up the fuel gauge was registering nearly empty. I took the boat and pumped in 9.5 gallons of gas when the pump cut off(but this is another issue). I took the boat home and mixed in the appropiate amount of 2 cycle oil and covered her up for the weekend. Now 2 weeks later the temp. has changed about 30 degrees, from 35 to approx. 60, and the fuel is spewing out of the fuel cap.<br />Is this because of the temp. change and maybe some trapped air???.<br />I have had the boat for little over a year and this is the first time this has happened in the winter.<br />I have had to siphon out about 2.5 gallons of mix to stop the overflow, i'm hoping this has fixed the problem.<br />Anybody with any ideas and more knowledge????, I sure need some help on this one. <br /><br />Thanks,<br />Nofish95
