Fuel Tank Capacity
Kelsie Laine
Help? Can someone tell me the fuel tank capacity of a 1987 WINNER Escape 1950 (Cuddy Cabin). <br />Engine is 5L 205 HP with Alpha Drive.<br />Thanks all!
Fishermark
Re: Fuel Tank Capacity
I can't, but to find the capacity of mine, I looked and there was a little tag near the sender which gave the particulars of my tank - including capacity. (110 gallons)
Kelsie Laine
Hi 'Fishermark' - thanks. I am embarassed to show my ignorance but ........<br />where is 'the sender' located?<br />Is my face red!
JB
This is not an engine problem. It is a Boat question.<br /><br />Moving to Boats.
Fishermark
No problem - I only learned by looking! (I'm naturally curious ;) ) Somewhere on your deck, above the fuel tank there is more than likely an inspection plate. Just pry it up, (or unscrew it as the case may be - depends upon the style), and it should be there. I believe most boats have a plate above the sender area. On my boat, (a 24' Sportcraft) there is also a large cover over the entire fuel tank. That is also removeable. You will have to do some exploring! :D
Kelsie Laine
Thanks again! "With the passing of each wave - I try and learn something new."<br />Your patience is appreciated.
