Engine sometimes - but not always - loses power and runs extremely rough above half throttle. <br /><br />After shutting the engine down for 5 minutes it will usually run fine - sometimes for only five minutes, but sometimes for days. Problem is becoming more regular lately.<br /><br />Remote tank was cleaned and gas lines and tank pickup tube seem to be leak free.<br /><br />Priming bulb never gets hard. Mech. replaced with generic bulb - still soft; I replaced it with a factory bulb - same problem.<br /><br />In-line fuel filter - located between the bulb and fuel pump - never gets full regardless of the number of times the bulb is pumped. Pumping the priming bulb however does pressurize the filter - evidenced by gas squirting out when I disconnect the fuel line to the filter. <br /><br />Other posts saw this problem disappear by relocating the filter to upstream of the bulb but the present location appears to have been put there by the factory. <br /><br />Is relocating the filter a realistic solution to this problem or should I look for other solutions?
