I have a 1977 Mercury 1500 (S/N 4750384) that is starving itself for fuel. I have cleaned the carburetors but the only way I can get it to cold start is to manual spray some fuel in the carbs. Motor has good compression on all six cylinders. It has eletronic choke on top two carbs but it won't pull any fuel when choked, anyone got any ideas why, last year I could choke a little bit and it would fire up and run fine. This year it won't start without spraying fuel in carbs and dogs and wants to die if you go past half throttle while under load, runs good on muffs. I am going to try to rebuilding the fuel pump but when I look up my motor on iboats I get the wrong fuel pump kit. Searching on other sites I believe my motor came with two different styles of fuel pumps. The one that shows up on iboats is the Sierra 18-7807 but the one I think I need is 18-7813. Thanks for your help.
