Fuel Sending Unit
shiftwork
I installed a new fuel sending unit because the old unit was not properly secured to the tank. Any way now it is all installed and the fuel gauge is reading empty. I took the sending unit out and manually moved the float arm and the fuel gauge does not reflect any change. However if i put the ground wire touching the sending wire(pink) the fuel gauge jumps to full. in addition there were three wires running to the old sending unit I thought there should only be two. There is one pink ( i beleive that this is the sending wire) which is hooked up to the main post from the sending unit and two others (i think green and ????) these two were under one of the screws that secures the sending unit to the gas tank. I put the wires back onto the new sending unit exaclty how they were on the old sending unit and the fuel gauge is not working now.. I know this is probably written very confusingly OBVIOUSLY I AM CONFUSED any help ar advice would be GREATLY APPRECIATED thanks you
