fuel sender Larson Lazer not reading right
Lazer89
I have a 1989 Larson Lazer and the fuel gauge reads empty when the tank is still half full. I pulled the sender today and it has a cork float on an aluminum arm. It appears that the arm is the wrong length. Does anyone know of a replacement unit that will work?
Re: fuel sender Larson Lazer not reading right
Ayuh,.... Welcome Aboard,... Just bend the 1 you've got to be more accurate,...
MH Hawker
And replace the cork while it apart.
Silvertip
Honorary Supreme Mariner
Length of the arm is not the problem. Sender depth and a soaked float may be.
Lazer89
I did some internet surfing and found a "reed valve" sender made by Moeller Marine. Its essentially a tube with a collar float that rides vertically on the tube. Got it installed earlier this week and so far so good.
