1979 Wellcraft 470 Mercruiser 2/B Rochester carb ..Went out on the bay last week and started to drop RPMs (Just a lil )then pick back up again, ran about 10 miles, As we slowed down to fish it started to run rough and when i put it in nutral it cut off and would not restart. (No fuel in carb,) so i pulled the bell off the fuel pump and it was dry, filter clean,I would have though that gas would have gushed out, fuel vent was clear, So i sprayed some WD40 in to the Fuel pump and this did the trick to get me started, So we headed back across the bay, Ran good untill about 1 mile out ,started to break down and run rough but we made it to the ramp, put her in nutral and that was all she wrote , Went home and did some work on her. Cleaned filter in fuel pump, filter in carb, Fuel water/Sep filter, new pionts & cond. Went out to fish today , Trolled for about 3 hrs with no trouble, But when we stared back in I had the same thing happen as last week. Removed the fule pump bowl and it was dry again, WD40 worked again (Is this right ? Should fuel flow back to the tank? Or is my fuel pump going bad? I will recheck my ANTI,S/V but I think it is OK. Thanks in Advance for your HELP.........
