fuel questions 96 wave venture
needanswers
i have a 96 yamaha wave venture 700 i would like to find out what the oil to gas ratio is and i dont have a owners manual. 2 i cant get gas to goto the carb with out blowing into the out gas line and it will not stay flowing any solutions ? could i put a fuel pump on it and if so what kind and how much ???
artificialreef
Re: fuel questions 96 wave venture
this is one of the reasons i will not go to pre mix and still have my oil pump installed. Think about it. You are running pre mix. You are turning your motor over. How does this pre mix motor get lube. From the fuel you say is not getting to the carb. Not good. There are alot of folks that say go to premix but when i have to trouble shoot a ski i usually have to turn it over to see whats happnin. I know i didnt answer your primary question but i hope this gives you something to think about. Side note my neighbor is on his 3rd 2 stroke boat motor because he was always working onit and turning it over with no fuel getting to the cylinders. He runs premix (or ran premix)
artificialreef
Oh to comment on your 2nd question. A properly functioning carburator will draw the fuel just fine. You do not need a fuel pump. Probably a carb rebuild or first make sure the input and return fuel lines on the carb are not swapped.
The Penguin
almost any yamaha dealer should carry re-build kits, or can order the proper one for you.
