Fuel question
handle
I have a built in above deck fuel tank, been thinking about installing a anti-siphon valve or shut off valve, which would you install? Just purchased the anti-siphon valve, seems to reguire alot of vacuum to make it draw. Worried about fuel starvation to the motor. Whats your take on this matter?
Chris1956
Re: Fuel question
I would use a shut off valve. Since the tank is above deck, you will see if the fuel starts to leak, therefore there is no need for the A-S valve.
