fuel pump
POINTER94
How tough is it to replace a fuel pump on an 88 350 mercruiser? I have the boat a couple of hundred miles away and can't picture the job.
Boomyal
Re: fuel pump
If it is mechanical, it should be two bolts, two fuel lines and a new gasket. Be sure to use a marine fuel pump. Failure of an automotive pump can fill your bilge with gas fumes. One turn of the starter and BOOM!<br /><br /> http://www.amarket.com/fuepchev.htm
Re: fuel pump
2 fuel lines...<br />2 bolts......<br />1 gasket.....<br />1 vent line....<br />Pretty Simple......
Boomyal
Re: fuel pump
Bondo: Ya mean that Chevy does not use the double diaphram pump? but a vent back to the carb instead?
Re: fuel pump
Boomyal,<br />You Snuck in on me as I was typing my post.....<br /><br />Ya, I've seen them both vented,+ Not.....<br />I'm just not Sure about the 1988.....<br />Some of them are Carters,+ some are ACs....
POINTER94
Re: fuel pump
Yes,<br /><br />It is vented with a hose back to the carb. Does that make it a carter? Thanks you guys are great.<br /><br />Doug
