Jim Robbins
- Jun 15, 2005
- 85
I/O Mercruiser with 140 hp. GM 4 cyl. motor 1973(?) and the previous owner instaled an electronic fuel pump(removed the mech. fuel pump). A fuel line runs from the fuel tank to the electronic fuel pump then to the carb. Should I have a over flow/pressure line returning to the fuel tank? I need to learn more about this, if there is too much fuel pressure is there a chance fuel is forced into the oil? I will prob. have to go to a marine mach. to check out what's been done, and if it will work properly. Any and all advice is greatly appreciated, thank-you
