Hey, my question is, I have a 1990 model evinrude 150 hp I have had lots pf trouble with the fuel pump on this outboard , I have found that the file pump is out . The reason I know this is as long as I pump the primer bulb a few times while I'm running down the lake the motor runs like a top as soon as I quit pumping it will die as soon as the fuel in the carbs. Are used. This outboard had the Vro on it but was disconnected I mix my oil and gas. My question is would there be some way of plugging off the pulse hose coming out of the crank case and putting a electric fuel pump on this engine, the actual fuel pump for this engine cost $389.00 without the Vro that's a lot of money to sink up in a motor that is 21 years old. There has to be a way to make a electric pump work. Thanks
