Do I need to drain the engine's oil before replacing my fuel pump?
I know the diaphragm separates the oil side from the gas side, but if the engine has been sitting I would assume all the oil is in the pan and thus will not start pouring out (other than just residual oil) if I remove the fuel-pump bolts, right?
Thanks.
Background Info:
- 165hp Mercruiser/Mercury Marine inline 4-cylinder/224cid engine
- Closed cooling system and an Alpha One outdrive.
- Mercruiser Transom Assembly Serial #: 0B689578
- Mercruiser Drive Unit Serial #: 0B701774
- Mercruiser Engine Serial #: B731211
Thanks.
Background Info:
